David Tonya
20 points
Posted on - 01/07/2013
Hi guys,
A problem with animated 3D text on excel. I cannot insert an animated 3D text on my Microsoft excel spreadsheet. I want it to be done to make my presentation more attractive, would you give me some secure application that can handle 3D animation or any SWF file extensions? I want to engage with 3D and other animation related application. Please inform me and discuss it.
Expecting some help, thank you.
A problem with animated 3d text on excel.
You can change the appearance of your text box by changing its fill or by adding rotations dimensional (3D). Click the text box to which you want to add remplissage.Pour add the same fill to multiple text boxes, click the first text box, then press and hold down the SHIFT key while clicking the other text boxes.
Under Drawing Tools, on the Format tab, in the Shape Styles group, click Shape Fill, and then do one of the following actions: To add or modify an integrated combination of effects, point to Texture, and then click on the texture of your choice. To customize the built-in effect, click 3D Options, and then select the options you want. To add or change a shadow, point to Shadow, and then click the shadow of your choice.
