Problem in Arcsoft using Windows XP
I need some suggestions of you in a problem that I currently have. As I’m currently having an acer aspire and I have windows XP in it, I faced a problem while using arcsoft total media 3.5 in it. When I open it, I keep the message “device is not available or is in use by another application”..
To find out the real problem, I disabled and enabled all the services again. When I disable it, video works great but without sound. Because computer its self is having no sound. I would like to know if there is any way to turn on the audio through partition of the hard drive and installing another XP or linux which may enable the sound drivers.
Please give me suggestions if you have any. I would be greatly grateful.
