I have windows 7 on my personal computer.
I have installed windows live messenger for Hotmail from the internet. but every time I login it disconnects after 5 to 10 minutes.
I am not getting any error, and I have also reinstall the messenger, but still this problem arises.
Please help me what to do?
Problem arises in hotmail messenger
You can check your internet connectivity for such purpose if you are using a wireless connection then check your IP address is it configured by you or by some DHCP. The problem may be because the IP is not configured and it changes after some times and this cause is a little disconnect in your service and you know when there is a disconnection then it automatically disconnects the messenger also.
So you can check you IP setting and other settings as well if there is some wire problem then you can check it also. If the problem is after some specific time say after 5 minutes then see the settings of your connection and see the messenger settings as well. It will help you to solve your problem.
louis
Dear Afsheen.Shahzad,
Login disconnects of windows live messenger after 5 to 10 minutes can be happened for several reasons.
If you have no problem with your software, it can be a cause of your internet connection so check your internet connection.
If you use wireless connection then check your IP address.
I think it will helpful for you.
Thanks and Regards
Louis
