Problem with ASuite and SuRun. ASuit access violation is shown
Hello experts,
 I have a problem with ASuite and SuRun. I don’t think so that I can fix this issue using Liberkey. Every time when I tried to start the program, I received an error message. SuRun is a part of ASuite so I hope you can fix this issue.
Thanks in advance.
Error Message: Access violation at address 00000958. Read of address 00000958
Best Answer by Waters Magner
Answered By 5 points N/A #184110
If in case you do not want to look at the portablizer again and again then in that case you need to strengthen the user. You need to give the user the administrative privilege. In that case, Liberkey is good enough to give the administrative privileges to various software like Firefox and CC cleaner. In such case you will ne able to get rid of portablizer and the above problem. Portablizer gives various software administrative privileges on windows when needed and if you need to get rid of it then you need to give the user, the administrative privilege.
Waters Magner
Answered By 0 points N/A #184111
Have you tried to uninstall and re-install the program(s)/add ons? If not, uninstall then re-install them, then try to use again. If that does not work, you may have to uninstall and re-install your version of Windows.
To uninstall a program:
1. Select start
2. Select control panel
3. Select programs and features
4. Select uninstall for the program or add on
