Hello fellows,
A problem with backgammon for Samsung wave. The Samsung wave mobile phone device has a bada operating system with 1.1 version. I cannot find the main cause of the crashing and not responding to the server errors. I wish this may not cause any harm in my mobile phone device system. Share some possible solution.
Thank you.
Karla Mmorrow.
I also have the samsung wave mobile phone which have bada operating system with 1.1 version.
I have easy solution for this problem.
This is fully compatible with bada operating system having 1.1 version.
Enjoy this game without any problem.
 You are using Samsung wave and looking for backgammon game for Samsung wave mobile phone device has a bada operating system with 1.1 versions.
As I reviewed your issue and found solution of your issue, If your backgammon is crashed, that’s not a big deal, You can again download the backgammon for Samsung wave from the mentioned link:
I hope it will helpful. Thanks!
