Problem with bitdefender 14 antivirus
Hello everyone,
I am using bitdefender 14 on my PC. When I update it, its serial number is not working. Can anyone help me with an active serial number of it?
Hello everyone,
Hello, If you have bought bitdefender 14 antivirus software you will have the original serial number. I think at the time of installation of the antivirus software you use invalid serial key. For that, when the software is downloading updates, the serial number is not working. You get the serial number for Bitdefender Antivirus Plus 2013 from this link : https://www.serials.be/serial/Bitdefender_antivirus_plus_2013_68543570.html
Hope, this will work.Thanks.
Hello, Don't worry at all. You know every online security provider are responsible for helping you by ensuring customer care system. In fact, you can get it. Your serial number might be lost. Whatever, you must contact to the support center of bitdefender 14 antivirus. They will help you by providing a serial number or any other measures what they can do for you. After all, there is no any other way of customer care. Best of luck!
If you are using the free version of Bitdefender, it shouldn’t require any serial number especially during updating. But if you are using the paid version or premium version, this is when a serial number is required. In the paid or premium version, the antivirus or security program is running on a subscription-basis. This means the program will work as long as the subscription is active.
When the time comes and the subscription has ended, so is your antivirus. It will also stop functioning and you will no longer be able to update it. This is probably what’s happening with your program. To make the antivirus active and work again, you have to purchase another subscription or renew your subscription. This will allow you to update the program again.
If you can’t renew your subscription, you have to uninstall the antivirus because it will no longer protect your computer. One workaround to this is to install the free version. Download the free version of Revo Uninstaller and install it. Once installed, start Revo Uninstaller then select your Bitdefender antivirus among the applications and click “Uninstall”. Follow the normal uninstall process.
When you are prompted to restart the computer, click to restart later. When uninstall is complete, click “Scan” to scan your computer for any leftover files and delete everything it finds. This removes everything the program created on your computer. When it is finished, close Revo Uninstaller then download the latest Bitdefender Free Antivirus.
The latest version at the moment supports Windows 7 Service Pack 1, Windows 8.x, and Windows 10. It requires 2 GHz Intel Core Duo or faster processor, 1.5 GB RAM, and 800 MB free space.
