After installing bitdefender in my computer I am facing problem with bitdefender certificate authority. I cannot open some secure website. Bitdefender CA not approved some of secure website I used before install it in my computer. Â I tested the same network with other computer and it works well secure website Is there any solution?
Problem with bitdefender certificate authority.
Greetings Russel! The problem may be because the software detected the web site is not secure or has an expired certificate. Try checking your system's date and time because some site certificates check the time and if it is before or after the time it will detect that something is wrong. If the problem is still there, try removing BitDefender and check the site. If everything is back to normal, you may need to change your antivirus to other alternatives. Cheers!
Hello Russel C Brannon,
         If there are some websites which are not working at your side due to bitdefender then i think that you have to try HOTSPOT shield that can help you in opening all sites which are blocked at your side. You can easily download it and can use it in your Pc. I am giving you the downloading link from there you can download it easily.
http://download.cnet.com/hotspot-shield/
