Problem to boot the computer
I have a problem in the boot of the computer during operation of the BIOS. Here is the display:
Press DEL to run setup
Press F8 for BBS POPUP
1 AMD Morth Bridge, Rev E6
Initializing USB Controllers ..Done.
2048MB OK (Installed Memory Size: 2048MB)
And then the PC is locked. Just as I press the reset button for the PC boots normally from the sequence without blocking.
On the other hand this phenomenon is not systematic but is rather annoying.
I reversed the memory modules to no avail.
My motherboard is an ASUS A8V-VM SE with Athlon 64 3700 +
Thank you in advance for information to help me fix this.
Best Answer by Whudson Audrey
Answered By 590495 points N/A #83207
This problem is usually associated with the motherboard. And a motherboard is not repairable. I also encountered a quite similar problem with the computer I once fixed. The problem was that the computer can not boot and they see an error on the screen.
When I checked the motherboard I found what is causing the error and it’s the RAM memory. When the RAM memory card replacement arrived I installed it and the computer is back to normal.
But the odd thing I noticed while I’m checking the CPU is that it responds very long. I spend my time checking every setting in the BIOS and every time I save the current configuration, it responds very long.
I thought the motherboard got locked up after saving because it didn’t respond immediately like what other computers do. But here, it took about 30 seconds before the system starts rebooting again.
This is only a sign that the board is already beginning to fail. Consider replacing the motherboard. There is no problem with the BIOS’ setting. It’s the onboard chips that are beginning to have problems.
Answered By 0 points N/A #197050
This concern is generally for this motherboard. And a motherboard is not repairable. I also found a rather equivalent trouble with all the laptop or computer I as soon as repaired.
The condition has been that this laptop or computer can not boot and they notice an error on the display screen. Once I tested the motherboard I found what is causing the error as well as it’s the memory.
If your MEMORY storage device alternative appeared I mounted it and the laptop or computer will be time for standard. Even so the weird issue I recognized though I’m verifying the CENTRAL PROCESSING UNIT will be it responds very long.
I invest my own occasion verifying every placing within the BIOS as well as each and every time I save the existing construction, it responds very long.
I thought the motherboard got secured up after preserving as it didn’t act in response right away similar to what other personal computers do.
Yet in this article, it had taken about thirty seconds ahead of the process will begin rebooting yet again. This really is just an indication that this board is starting to be unsuccessful. Contemplate swapping the motherboard.
There is no trouble with all the BIOS’ placing. It’s the on the machine chips that are starting to have got problems.
I hope it helps you.
