Problem with burning a CD using Realplayer 32-bit
Hi!
I have a problem with burning a CD using Realplayer 32-bit.  Along the process of burning, I am prompted with this annoying error message – “Please ensure that your disc is clean and not damaged, before attempting your burn again. If the problem persists, try burning with the option to add 2-seconds between tracks, if applicable. (1014)”.
Please help me find a solution for I am hopeless.
Thank you!
Answered By 5 points N/A #145307
Hi there user:
As I have searched regarding your post, unfortunately Real Player has no solution to fix this issue (remove the error). See this link. http://www.faultwire.com/solutions-application/RealPlayer-*7704.html
Instead, they've launched a new version as a recommended solution. It works for so many users anyway, shrugged-off as they’ve no choice. Here’s the freeware (New Version of Real Player) to download. https://apk-dl.com/gingerbread-tweak Install and start burning CDs again. Don't forget to uninstall the previous version first.
I hope this could solve help.
Best regards,
