A problem with cad for music studio.
Hello experts,
A problem with cad for music studio. The cad audio cannot be imported or not supported by the music studio, is there a way that I can import the cad audio in music studio software even for a while? I want to edit some voice and scenes, I am using windows 7 os. Thank you.
Best Answer by Jack Jhonny
Answered By 0 points N/A #174517
Hi Mellisa Wright,
You must download a window 7 codec pack for your computer, you can download it here:
http://www.softpedia.com/get/Multimedia/Video/Codec-Packs-Video-Codecs/Windows-7-Codec-Pack.shtml,
and if this codec pack didn’t work you may try this codec instead:
http://codecguide.com/
Answered By 0 points N/A #174518
To solve the problem you have use additional tools. You can also download any one of the 30+ software for voice and scenes editing. That are absolutely free and work well. As an example you can use image rasizer software. You can download the software from the link which is given below: https://www.hongkiat.com/blog/30-free-online-multimedia-photo-audio-video-editors/
I think that will be helpful to you.
Answered By 590495 points N/A #174519
The reason why you can’t import any audio files is that both your software only supports very limited audio file formats. Since the other software can’t read the audio file from the other, why not try converting the audio file to the format that your software supports. I have a video converter that is good in extracting audio material from video besides converting different video materials.
You may visit ImTOO and then download the converter there.
They have different Windows and Mac products. Like for Windows users, they have products like:
iPod/iPhone/iPad Tools
  • iTransfer Platinum
  • iPhone Contacts Transfer
  • PodWorks Platinum
  • iPad Mate Platinum
  • iPhone Transfer Platinum
  • iPhone Transfer Plus
DVD/Blu Ray Tools
  • DVD Ripper
  • Blu-ray Ripper
  • Blu-ray to MKV Converter
  • Blu-ray Creator 2
Video Tools
  • Video Converter
  • 3D Movie Converter
  • Photo Slideshow Maker
  • Online Video Converter
And for Mac OS X users, they have:
  • iTransfer Platinum for Mac
  • iPad Mate Platinum for Mac
  • PodWorks Platinum Mac
  • iPhone Contacts Transfer Mac
  • Audio Converter Pro Mac
  • Video Editor 2 for Mac
  • iPhone Ringtone Maker for Mac
  • YouTube HD Video Converter Mac
After converting the audio file from Cad Audio, try opening it on Music Studio then do your editing there.
