Hi Team ,
I want to know how to use black ink only on my Canon MP530. I refilled the colored and black cartridge of it but I don’t need to use the colored one. I refill them both because my printer keeps on showing me that the cartridge is empty. Please Help
Thanks
Problem With Canon MP530 Any help
Hello there! If you are printing an image, you can turn the image into black and white or grayscale. The printer will print the image using the black ink only. Double click on the image and the image toolbar will appear. You can adjust the color into grayscale, black and white, watermark and to its default color. Another option to print only in black ink without modifying the colors in your documents is to go to File > Print > choose Canon MP530 and then click Properties. In the printer settings, click on the “Black and White Only” then Apply > OK.
