Problem with the chat room codes html
Good day Techyv Users, friends and pals!
Hi, you can use chat-room plug-ins. Choose one that supports the technology that you used to develop your website.
These plug-ins can be found which is a php plug-in website.Â
You can also build your own using real-time protocols.
One, which is open source, is xmpp. Many tutorials exist for this protocol.
I hope this helps.
Hello Jess wwagner !!
Since you are having an issue related to embedding the chat-room to your basic HTML code. So for creating the chat-room which is to be used in your blogs and the web pages you need to use some java templates and then embed them to your HTML page using the address of the java interface you created. And then use the particular java address to embed your chat-room where-ever you want. And to add the chat-room to the website you must use the syntax as, embed src=("address _of _the_java_page") and your java created chat-room will get embed to the page.
