A problem with Cisco cable modem drivers for Windows 7.
Hi guys,
A problem with Cisco cable modem drivers for Windows 7. It seems like the driver was not installed properly because the internet connection is not stable. It was not perfectly set up and I am getting error 23, do you think this has to do with my cisco cable modem drivers for windows 7? I need your expertise.
Expecting some help, thank you.
Best Answer by Fenster Maxine
Answered By 0 points N/A #172271
Hello Debra,
There should some issue with the system type between the two devices. Try to check if your computer and the modem installer are both 32 bit or they're both 64 bit. They should have the same system type to function properly. And try to re-install as well.
Thank you.
Hope it helps.
Answered By 5 points N/A #172272
Hi Debra Carter,
I have reviewed your problem of Cisco cable modem drivers for Windows 7 and found the Cisco cable modem drivers.
You can download drivers and user manual of Cisco cable modems from the Official website of Cisco.
I provide a link for downloading Cisco cable modem drivers for Windows 7, Please visit on below mentioned link for specific drivers of Cisco cable modem drivers:
http://www.cisco.com/web/consumer/support/modem_DPC2100.html
I hope it may be helpful. Thanks!
