stevecanry
1660 points
Posted on - 06/28/2011
Hi all,
When I try to use two browsers at same time, I meet an error, specially in closing both browser.
I am pasting below the screen shot of the error, for better view of the problem.
Another instance of Opera is still in the process of shutting down.
Please wait until it finishes, or terminate it using the task manager.
Press retry to restart Opera, or cancel to quit.
Retry Cancel
When I encounter this message, I restarted my computer, to have a fresh start. Whenever I am working with two browser to surf the internet, there was no problem working in it. When time comes that I am done with my work, closing the two applications is very hard. It takes time to close the next browser after the other. I already tried re installing opera browser.
Please share some ideas on my issue.
A problem closing two opera browser
Hi, i will try to solve the solution the best way i can.
According to my understanding you seem to have opened two separated browsers for surfing the net. Such a method takes a toll on the computer and processes tend to slow down or cause errors like you have encountered. Try opening another tab within the same opera browser to make it easier. You can do that by clicking 'File' in the menu and then click 'new tab' to add a new tab.
If the problem persists, then it must be a bug. Uninstall the software and install it again. From there it should be fresh and working well.
I hope i have solved your problem.
You need to reduce the RAM or virtual memory of your computer since it might also be the problem affecting the application. You may also try scanning your system for any viruses or Malware. You may uninstall the application and install a less instance of the application to see whether it will solve the problem.
You need to be using one browser at a time in most cases to reduce the problem. You can install another type of browser like Firefox, or Internet explorer 8, or even flock.
Once you install the browsers,they will function normally,
