Problem communicating with GPSMAP 62s
Hi guys.
I use a much older version of basecamp, and while I was downloading that I also downloaded the latest software for my sixty two series – (I'm on a keyboard where the "two" isn't working!).
I can't get rid of this error message that’s why I've downloaded and removed basecamp twice:
Error
There was a problem communicating with GPSMAP 62s (Unit ID 3813189875) (E:) An error occurred while reading the following file(s)
E:/Garmin/gpx/imported_29-DEC-10 040952 AM.gpx
Any cure? Thanks in advance.
Answered By 25 points N/A #109243
It tell you that it can't find or contact the file E:/Garmin/gpx/imported_29-DEC-10 040952 AM.gpx please try moving it on your drive C: maybe it will work.
And can you answer my questions is the drive e: and external drive or a flash drive? if yes please make sure your connection between them is not faulty but if it is a partition please check your hard drive if it is still good run some chkdsk to make sure you have still a good drive and for it to fix some errors if there are.
Hope this will solve your problem and enjoy your stay here.
