Hello there! I am trying to open my hazelhelper, but an error message appears stating a missing component. I just wanted to know the problem regarding my hazelhelper downloaded from internet. What will I do?
A problem in component on Hazelhelper downloaded from internet
Sometimes, the antivirus software deletes the infected parts of the application. Then, the application does not fully work without the missing component.
Your error message indicates these types of problems, so it is best for you to install the application again. Then, restart your computer. Next, disable your antivirus software for a few moments, then try to install the Hazelhelper application. After the installation ends, open it.
Now it should work easily without any error message.
