arturo owen
10 points
Posted on - 03/29/2012
I am having trouble with detecting my Bluetooth device. So far it was working automatically with the startup but now then I look for it I cannot find it anywhere. I have look through everywhere but there is nothing that shows that it is the blue tooth.
Someone kindly instruct me what to do.
Arturo Owen
Problem with connectivity- devices detector not found
This problem occurs when Bluetooth adapter turned off. If you turned off your Bluetooth adapter, than system tray icon will automatically hide. Find out the Bluetooth switch in your laptop. Different laptops have different keyboard arrangement. Like
1.      In dell laptop you will found it in F2 button. Press F2 or Fn+F2 button to turn off or on your Bluetooth
2.      In HP laptop, Bluetooth button situated in top of function key. It’s generally has a Bluetooth icon. Press that button
3.      In Sony Vio laptop, you will get Bluetooth switch in front of touchpad. It’s generally labeled with Bluetooth
So find your Bluetooth switch & turned it on. Your problem will be solved
