Problem To Convert Hyper-v To VMware.
I am having a problem in converting hyper-v to VMware. Can someone pleasebrief me about how this problem could be solved? Please help me out.
Be thankful to the mighty Vmware vCenter Converter as it is pretty easy to convert a Microsoft Hyper-v virtual machine into an ESXi (vSphere) one. You need Windows Server 2012 and higher. Here is the download link for the converter;
Do not use the converter plugin on the vCenter Server, instead try to use the stand alone converter. Use the Hyper-v VM as a physical VM, which means power it on and then use the converter.
