Problem with CorelDraw 15 Clean Tool?
Hi Friends!
I am looking for the Corel Draw 15 clean tool, can anyone please help me? I want to know if there is a so called clean up tool in the Corel Draw 15 or X5 versions. Has anyone tried using Corel Draw X5? If yes, then please give me guidance. Can you also provide a tutorial on how to use the different tools in Corel Draw 15? If you can give us some information on the handy tools which you're using in your works, then it will be very useful.
Thanks,
Ammelia Jesse
