I am facing a problem with cross domain. I use, VS 2010, SharePoint Server 2010 and InfoPath 2010. I am facing problem with data connections. Tell me, how to cross domain them. I have tried many things like UDCX files and modifying them before upload. Please, help me!
lee hung
75 points
Problem with cross domain with VS 2010, SP 2010 and InfoPath 2010
Hello Charlene_Crosby,
Instead of using the cross domain, you might as well try copying the UDCX files which you had created in the DEV and then uploading them to production and see if that is going to solve the problem that you are having.
But if you still need to cross the domain, then I will advise that check configuration of the InfoPath via the central admin, it may be having issues that you will need to fix, and I will refer you to the following website that will give you a step by step guide for cross domain connectivity when using InfoPath.
InfoPath, SharePoint and cross domain issues
Hope this helps.
__
Regards
Lee Hung
