A problem with cs5 free for mountain lion. I don’t think it cs5 adobe media applications are compatible with mac mountain lion operating system. I want to know first all the terms and condition before making some critical move. When it comes to software we have to be very careful.
Waiting for your support, thank you.
Hi Brenda,
Both Apple and Adobe claim that they have extensively tested CS5 with the Mountain Lion OS and there are no issues with the compatibility, but based on the user feedback and issues reported by many users, I would not recommend you to use CS5 with Mountain Lion OS.
You can check the compatibility and test result details at the location below and then make a decision based on your requirements.
https://roaringapps.com/apps
