Problem with dedicated camera key on Sony Xperia U
Harford Maud 30 points N/APosted on - 06/18/2012
Just bought a new Sony Xperia U and I am having problem with its dedicated camera key. Although the camera works flawlessly but the camera key does not always respond. Is there anyone with same problem?
Sony Xperia U is a good model to date from Sony, these are the first batch of Xperia Phones Sony has released without the Trademark of Ericsson, including the Xperia Sola, P, S, Ion. More of these phone models will be released soon.
Sony has a good camera feature that you can lean on when photography matters. Xperia U has this dedicated camera key for opening the main camera or the front cam, and for taking snapshots, though you can also use the touchscreen to open the device.
I feel what you want to convey, and for that, I think I have suggestions for you to check on whether your problem can be solved by your own or you need service or what.
Have you checked the power button if it just like your dedicated camera that is somewhat irresponsive?
Have you tried removing the case of your Xperia U and tapping the dedicated button? (it might just be something like the Design cover or form factor that hinders the response of the key)
Lastly, is your device been used for more than a hundred times (I mean clicking the camera key), it might just be brought by the NEW device and needs to be used frequently to soften it.
The Sony Xperia U is a 3G Smartphone operating on 2G and 3G network bands using GSM and HSPA technologies. It was unveiled on February 2012 and released on May 2012 measuring 112 x 54 x 12 millimeters and weighing 110 grams. It uses mini-SIM card and has TFT capacitive touchscreen display with 16M colors at 480 x 854 pixels screen resolution.
Sony Xperia U
It supports multi-touch up to four fingers protected by scratch-resistant glass. It runs on Android 2.3 Gingerbread upgradable to Android 4.0 Ice Cream Sandwich powered by NovaThor U8500 chipset, 1 GHz Dual-Core Cortex-A9 processor, and Mali-400 GPU. microSD is not supported. It runs on 512 MB RAM with 8 GB internal storage where 4 GB is available to user.
The primary camera supports 5 megapixels with LED flash and autofocus featuring geo-tagging, face and smile detection, touch focus, and panorama. It can record video in 720p at 30 fps. It has a secondary VGA camera.
It has 3.5-millimeter jack featuring Sony 3D surround sound audio technology and Active noise cancellation with dedicated mic, Wi-Fi 802.11 b/g/n with hotspot and DLNA support, Bluetooth 2.1 with A2DP and EDR support, GPS with A-GPS support, stereo FM radio with RDS support, and microUSB 2.0 with USB Host support. It has built-in accelerometer, proximity, and compass sensors. The pre-installed web browser supports HTML5 with Adobe Flash support.
Java is supported via Java MIDP emulator. It runs on removable Li-Ion 1320 mAh battery with standby time up to 260 hours on 2G and 472 hours on 3G. Talk time is up to 6 hours 36 minutes on 2G and 5 hours 36 minutes on 3G. If the camera buttons don’t work properly, try doing a soft reset since its battery is removable.
Turn off your phone then remove the battery for about 10 to 20 seconds. After this, reinstall the battery and then start the phone. See if there’s a change in the camera buttons. If this doesn’t work, try factory reset. Before doing a factory reset, back up your phone’s data.
1....
