A problem with deep clean format windows. I reformatted my Windows 7 starter Os in my Hp laptop. There is this problem that cannot load up and restore my back up. I need the files as soon as possible for it contains important data for the business proposal and projects of the company. Can you give me some ways to resolve this issue?
Waiting for your support.
Hi! Kurtt. I might have a solution for your problem. You see, everytime we attempt to format our laptops or computers the system will divide the hard disk, the Local C and Local D. Prior in doing so, we forget to back important files stored in our PC before formatting resulting to the loss of files. But there are softwares available for you to buy or download over the internet but it’s not free of charge you have to buy it in order to full access in using it. Some Data Recovery Softwares has a free trial but this free trial doesn’t't mean that you can recover your files using it, it will just show you the features of the software, before you can recover your lost files, you have to buy it first. Take note that if you finished formatting and lost your files, don't used the drive you just formatted until you recover your files because ones that the file in that drive is overwritten it will be impossible for you to recover your lost files. One of the top Data Recovery Softwares is DiskInternals Partition Recovery it can recover formatted, corrupted, and deleted partitions.
