dgsabel
Posted on - 10/31/2011
Hi Team ,
I’m wondering what’s wrong with the installation disc of my router. I run it using my laptop but on the set up screen, there’s no option button that can be clicked. My laptop was able to run other discs and when I tried the installation disc on another computer it works as well.
So which one of them has a problem? Is there something wrong on my laptop or the disc itself; why can’t it run properly on my laptop alone? Any help please and Thanks in advance!
lee hung
75 points
Problem with this Disc for my Router
You must check your DVD/CD ROM, if it is working correctly and then check your CD installer to your router, if it working impeccably because certain installers on your software may be scratched or corrupted. If the problem is the CD installer you have a different unique installer to your Router or try this one. Download the different installer version for your Router and just simply look for possible software that can suit your computer, to have a software that is compatible to your Router and then specially to your computer to avoid any problem or error again.
