Problem with .dll files missing.
What is the problem here? After I install applications it always says that “********.dll” files is missing. Can you help me find those .dll files?
Usually, .dll errors or problems occur after installing an application or uninstalling software and caused corruption with .dll files. This file type that is missing in your computer will make your Windows not to work properly. In your case, you mentioned that you just installed several applications so that what explained it. It is actually not your fault; it could be one of the applications that caused it. Since you installed new applications, new .dll files has been added to your Windows PC and if one of those corrupt, and that corrupted .dll file is needed by Windows then it will give you errors.
What I can suggest is that you download any dll fixer like this: https://www.dll-files.com/ to help you with dll problems.
This is very familiar to me and I always experience this especially when I’m installing emulators. It is very common when a user installs a not so very common application. I think the reason why some applications tend to have missing DLL files is because they don’t write the DLL file themselves for their application and they only borrow it from other programs like from other Microsoft applications.
But there is really no problem even if you have missing DLL files after the installation. It can always be fixed by supplying it with the right DLL file. Whenever you encounter an error that is associated to a missing DLL file, you need to get the filename of the missing DLL file. Take note of the filename and visit DLL-files.com.
This is the best source for whatever missing DLL file you have. It has a good collection of different versions from various operating systems. Once in the site, the fastest way of finding your missing DLL file is to select the first letter of your DLL file on the website because the entire database of DLL files are sorted alphabetically.
Just follow the steps on how to download the file. And also, make sure to check the version of the DLL file you are downloading. It is always indicated in the file from what operating system it is compatible with.
Hello Ariel,
There is another techyv page from where you can get vital information about .DLL files missing.
So my recommend is visit "Game won't play on Windows 8.1" this techyv page too.
