I have a system that runs XP Service Pack 3.
The problem is that I can not install browser Google chrome installation at the beginning.
This window is popping up that shows not only in Google chrome but also in many programs.
What the solution please?
Error:
ChromeSetup- 16.0.912.77.exe – repositionnement de DLL système non autorisé
La DLL système user32.dll a été repositionnée en mémoire. L'application ne s'exécutera pas correctement. Le repositionnement a été
fait car la DLL C:WINDOWSsystem32SHELL32.dll occupait une zone d'adresse réservée pour les DLL système de Windows NT. Le
vendeur ayant fourni la DLL doit être contacté pour en obtenir une nouvelle.
Problem Dll systéme non autorisé
I’m sorry but the dialog box is in French. I wish you include the English translation of the message inside the dialog box so we can fully understand what it says. But anyway, I tried translating a few. I’m thinking that the system you are using is not compatible with Google Chrome.
If you are using an earlier version of Windows like Windows NT for example, I’m not sure if this is compatible with the application. But when you say that this error happens a lot every time you install something on your machine, it is possible that there is something wrong with your operating system.
Try checking your computer for any possible errors. Use a disk utility application when checking the system. Maybe there is an error in the file system of your hard drive and it is conflicting with the installation that you are doing. This will not only affect some installation but other applications as well. If you can’t find anything, you may try formatting your hard drive and install Windows again.
