Recently after upgrading our Domino server to version 6.5.1, I have run into some errors. During installation I enabled the scheduling agent and had the admin as the signer of the code.
The problem is that the weekly scheduled agent is not functioning in accordance with the timing. When you configure it to run once a week it fails to do so yet when you configure it to run after a few hours let’s say two hours from that instant it will run. I would be glad to receive some help.
Problem with domino server on scheduling agent
Hi Adrian Johson,
Currently, there is a new update because of that error you are having. IBM is having issues because of the older version (the one that you are using). Kindly download and change the version you are using by downloading the update on this link that I will be providing.
Now after downloading it, make sure you will not run it immediately. Kindly uninstall the Domino that you are using right now and then install the older version that you are using before version 6.2. (Version 6.2 has files the will or might affect the installation of the latest version that you downloaded).
Now after doing all of these you can now run the file that you downloaded in the first step.
1. Run the file that you have downloaded.
2. Wait for it to finish its update. And if you have an error while installation kindly make sure that all the Files of version 6.2 is removed, if not delete them.
3. Now after that kindly restart your domino and you are good to go.
Good Luck. For any further question you can send me a message.
