A problem with download acer aspire upgrade wizard.
Asked By 460 points N/A Posted on -
A problem with download acer aspire upgrade wizard. I think the upgrade wizard for my acer laptop is not working properly, there are no updates prompting when I am internet connected. Please let me know the main purpose of acer aspire upgrade wizard. Thanks.
Benjamin.
Answered By 0 points N/A #92387
Benjamin,
Simply because your Upgrade Wizard is not announcing updates, does not mean that it is not working.  Ensure that you have enabled the settings to notify you prior to all updates instead of simply updating your system.
     Open up your Upgrade Wizard and check your settings.  Check the appropriate setting for being notified of all downloads and installations prior to installing.  At the bottom of this post you will find a few web sites that will have more information.
https://www.acer.com/ac/en/US/content/upgrade-assistant-tool
https://www.sevenforums.com/installation-setup/37347-acer-upgrade-wizard.html
