Problem downloading iTunes help required
Experiencing problem here with iTunes Match, the problem is I cannot download or streaming from the iTunes, my iOS is not affected.
What happen?
I check the internet connection is okay, nothing wrong.
There was a problem downloading “You Can’t Always Get What You Want / Hot Rocks 1964-1971 / The Rolling Stones”.
An unknown error occurred (-2114).
Please check that the connection to the network is active and try again.
