Problem downloading the software for the iPad
Hello
I have been trying to upgrade my iPad, but it won't upgrade and results in the following error.
The screenshot of the error is as follows:
There was a problem downloading the software for the ipad “chow’s ipad”
The message states:
There was a problem downloading the software for the iPad “chow’s iPad. The requested resource was not found.
Can anyone please shed some light on the issue? I am at my wits end now. Waiting to hear from you all.
Regards.
Best Answer by RANDOLPH Rosa
Answered By 0 points N/A #160041
Hi Jermaineporterr,
It’s better for us if you tell what exactly those files are. This issue occurs mainly because the files you’re downloading has been cancelled or withdrawn by the author. Try other source of those files. Just keep continue searching and go to the forums for more info.
Answered By 10 points N/A #160042
You are facing that problem and i have solution:
1. If you are using antivirus or firewall then uninstall that and after that you can upgrade the software. When it is done then installs the antivirus.
2. You can use proxy to solve that problem.
Thank you.
