Problem with downloading switch Visio 2010
Hello everyone,
I am updating switch Visio 2010, but an error occurs while downloading. The problem is repeated every time. Can anyone tell me what I can do?
Thanks in advance.
Hello everyone,
Thanks in advance.
Thanks for your questions. When you are downloading updates of switch visio 2010, the following error occurs because the update you downloading may be damaged. For that you will get the error message. The files related to updates can be damaged.
Hope, you understand the point. Thanks, have a good day.
Hello, I think it's the server problem. It may be occurred for bad gateway of downloading process. The best solution can be happened if you choose alternative source for downloading. At the same time, you can check your download manager. I think Internet Download Manager (IDM) is the best solution. After all, you can also check your hard disk whether it's full or not. Sometimes, the full disk can show error. I hope you will find the problem. Best of luck!
Notifications
