Problem during BIOS update please help
Hi experts,
I need to know much about the Event Viewer and need to know the reason of the error.
I installed the BIOS update. But when I try to upgrade it from F.20 to F.21, all time the event 4 and 5 appeared.
Need your help.
Thanks
Error :
Event 13, ACPI
The embedded controller (EC) did not respond within the specified timeout period. This may indicate that there is an error in the EC hardware or firmware or that the BIOS is accessing the EC incorrectly. You should check with your computer manufacture for an upgraded BIOS. In some situation, this error may cause the computer to function incorrectly.
Log Name: System
Source: ACPI Logged: 30/11/2011 1:46:35 PM
Event ID: 13 Task Category: None
Level: Error Keywords: Classic
User: N/A Computer: PT-Laptop
OpCode:
More Infomation: Event Log Online Help
