Problem during download and installation of Frostwire
Hello, when I am using frostwire 5.2.9, initially it was okay but after some time being, there is an error on the status column. I tried to restart it and also reinstalled it later on but still stick to the error problem.
Please help me out, can anyone suggest me any kind of solution?
Answered By 5 points N/A #90476
Uninstall Frostwire. Also remove java. You need to remove all traces of the software. You can use Revo Uninstaller to do the same. Here is the link where you can get one: https://www.revouninstaller.com/. Windows uninstaller are not very good at doing a clean uninstall. Keep a backup of all the files before doing an uninstall to be on a safer side. Once you are done with this clean uninstall, Install Java. Here is the link : http://www.java.com/en/download/. Now install Frostwire. Here is the link :
Download link for FrostWire (Official Site)
