joan d vogt
10 points
Posted on - 09/18/2012
Hello everyone! I was just browsing on my photos and thought of editing, rotate in the batch organizer, when I added a batch this error just showed up!
Why am I having this error?
I tried doing two at a time but still, this error keeps showing up.
A single photo will just do fine but it would take me forever if I’m going to do it one by one.
https://www.flickr.com/
There was an error: <?xml version=”1.0”
Encoding=”utf-8”>
<rsp stat=”fail”>
<err code=”3” msg=”Temporary failure” />
</rsp>
Problem in editing the photos
It’s a problem when you want to edit bunch of your photo together, and it shows an error message.
Bunch photo editing is really a bug problem. Sometime it’s not working properly.
If you want to see a perfect tutorial you can go through this website–
Here you can find the answer and hopefully you might get some help.
Hi!
It’s not a good idea to batch photo edit your images on Photo hosting sites or on any online tools.
As what you have experience, most of the time you get errors or it could not meet your target.
I suggest that you purchase or look for a free Photo Manager and try to edit or correct your photos there before uploading them online. It is much easier and faster to do it using tools rather than editing it all in batches online.
Here are a few I can suggest:
Picasa you can download this tool via Google
F-Spot fully featured Photo management software that is open source and runs on Linux.
FastStone this is an image viewer, a converter and editor. It also includes resizing and cropping photos. This runs on Windows.
VirtualStudio with this editor you can retouch and enhance your pictures by batch. It also has the ability to add copyright information on your photos.
