Mabel_owens
Posted on - 11/05/2011
Unable to edit my songs in my shuffle, such as deleting songs from my shuffle and adding new songs into it.
I have been using iTunes without any problems on my old laptop to add or delete songs.Â
Now, I can’t get it to work with both my new and old laptops.Â
I can’t add or delete songs from my iPod Shuffle.Â
Any ideas?
Problem with editing of Songs in Shuffle via iTunes
Maybe the iPod Shuffle's application that is installed on your computer has a problem. If the application is not functioning normally, it can not synchronize any task between the computer and the iPod Shuffle.
Check your hard drive for errors. If you have a disk utility application installed, run it to check your drive for any errors in the file structures that is affecting some applications from working properly. Or just use Windows disk check if you don’t have any.
Right click on drive C and then select Properties.
Click Tools tab.
Click Check Now.
Check Automatically fix file system errors and then hit Start.
Launch the iPod Shuffle’s application again and see if you can add or delete any songs now. If it’s just the same, uninstall the application from your computer and then install it back and try running the application again afterwards.
