Dale Afleck
Posted on - 08/12/2011
It was my leisure time to have games online in my computer.
I have downloaded Game Booster to help my system much better in performance when I'm playing games.
It was great having this application on my computer's system until last day; an error message shows up.
I include an image below with the error message:
i hope someone will help me with this kind of trouble.
Error:
Game Booster     Â
Could not convert variant of type (Null) into type (OleStr)
Boweee0
Problem encountered with Game Booster
If errors like this suddenly appears on your screen, then their could be something wrong with the programs internal.
It means that their are files that should be used in the program that is either corrupt or infected by a virus and it would not execute its main function properly that is why the software automatically generates such error.
The files/the programs internal that I have mentioned are those that are extracted during the installation of your Game Booster in order to be placed in the registry for the integration of the program for regular usage.
There are plenty of ways to resolve such issue.
Please be guided by the following:
Scan your computer for viruses or malware using the latest updated antivirus available.
Reinstall Game Booster by not uninstalling. Run the setup file again and you will be given two choices. It is either repair or remove if available. Choose repair and the program will fix it for you.
Always remember that Game Booster is a third party program and it may violate some of the Online games terms and conditions depending on the latest update of the game you are playing.
Clean your system registry using software's like Registry Cleaner/Ccleaner to avoid conflicting resource usage of the program. (Only perform after :: If you uninstall Game Booster)
