John Jun
Posted on - 09/21/2011
I Have set Mozilla to accept updates whenever one is available. I have no problem with that.
However, Â just recently, it seems that there are some updates whose automatic installations are refused and gave the error about malformed XML File.
Please refer to the image of the error included here. Please advise what to do to solve this problem. Thank you.
There were problems checking for, downloading or installing this update. Firefox could not be updated because:
AUS: Update XML File Malformed (200)
sibabu
5 points
Problem encountered in updating Mozilla
Hi John
this problem in your updating Mozilla can not find your Xml reader file on your Windows. Try to install real exe xml file or Install DreamWeaver for your system. Or below this link shown on your screen manually update from your requiring valid package.
Or your Mozilla version will not supported on your PC and network connection for updating. sometimes the speed of downloading might effect on application and software download.
You can try Re-install your Mozilla. follow the system: at first go control panel and uninstall the program from your computer. Shut down your PC then start your PC and install properly. i think you have solve it.
