Noel Viray
Posted on - 10/07/2011
I was playing MapleStory when this error message popped up (see error message below). Â
I have searched the web and it points me to a registry problem or to a Microsoft operating system-related problem.
I recently updated my operating system but this would have also caused some registry updates. So, which is which?
How would I determine which path to resolve this issue?Â
Please help.
MapleStory
error code: -2147221000
OK
Problem encountered when playing MapleStory
Solution 1
Download and install Registry cleaning software and then run it in your computer. Example of this are CC Cleaner or Registry Cleaner. Just simply scan your registry and fix all the necessary error provided that it is seen by the software.
Solution 2
Repair your OS to fix your registry, but there is a setback here, you might be required to once again install your game and other software because it is not running properly.
So basically, the idea is to do solution one to fix the error and the number 2 will be done if the registry is not fix.
This type of error usually arises while dealing with Macromedia Flash player utilities.
It has nothing to do with your registry settings instead of registry this error is directly associated with DLL files.
In order to get rid of this error message you have to install Microsoft Visual C++ 2008 SP1 redistributable package.
You can have this from the official Microsoft link.
