Problem Encountered while Converting PRN Flies
Hi
I need to convert a bulk number of .prn files to excel. So I need a fast convertor on my PC. I am using Windows XP. I also need the color sorting option available on my excel sheet after conversion. Most of the time converted files do not show this option available. Can anyone give me a better suggestion regarding this?
Answered By 0 points N/A #136253
Hello Edward
Using software in conversion always had a error problem. I am giving you steps to convert manually, just few clicks. Follow the steps
First start excels and views all readable files. Now select the prn document which you want to convert and open it. Select the Delimited radio button then click next.
Clear all the boxes under Delimited and click next.
After that click finish and your file is converted now.
