Problem with equalize aac Mac
I have Dell Inspiron 700m and I would like to know how to equalize aac mac? When I press the info window at the top, there is no equalizer graph when aac file is playing, but everything is fine for mp3. Moreover, equalizer presets do not affect the aac’s sound. Where is the problem-in software, aac, or somewhere else?
Answered By 10 points N/A #146886
To enable the equalizer presets follow the steps below:
1. Open the mp3 player and select the aac track you want to play.
2. Now go to the options tab and select audio settings.
3. A new window will open which has the audio settings. Click on the enable presets option, you will be asked for confirmation, click yes and save the changes.
4. Now, click on the sound settings and change the presets as you like. There are also a few pre-installed presets like rock, pop, etc. which you can select.
Hope this information helps you solve your problem.
