Problem with Exchange 2007 – Authentication Pop-Up box in Outlook
Hi all,
Can anyone please help with our annoying Outlook 2007 problem?
When staffs open Outlook, they are being asked to authenticate to our mail server – mail.school.worcs.sch.uk.
If they pop in with their user/password, they can then load outlook and carry on as normal. OR
If they first login to OWA webmail.school.worcs.sch.uk, they can then load Outlook.
Does anyone please know what is going on?
Also, here are the internet requests I captured with putty when they enter their credentials. Should Outlook in school be accessing webmail on https??
1299661532.801 0 10.50.4.15 TCP_DENIED/407 1308 CONNECT webmail.school.worcs.sch.uk:443 – NONE/- text/html
1299661532.807 3 10.50.4.15 TCP_DENIED/407 1620 CONNECT webmail.school.worcs.sch.uk:443 – NONE/- text/html
1299661533.021 208 10.50.4.15 TCP_MISS/000 12945 CONNECT webmail.school.worcs.sch.uk:443 test.teacher SOURCEHASH_PARENT/Staff –
Thanks in advance!
Answered By 590495 points N/A #141907
If your Microsoft Office Outlook 2007 is configured properly then I think this problem wouldn’t happen. If this is the first time that this happens when accessing Microsoft Office Outlook, try closing the application, restart your computer then try it again.
See if you don’t receive any dialog box popping up after rebooting the system. If it’s the same, try checking the settings of the application. I suspect that the software is really not configured properly.
If it still doesn’t work, you may also try doing a clean installation of the program to fix and clear your system from any corrupted files that may be present in your computer. Uninstall Microsoft Office Outlook 2007 then restart your computer.
If this program is part of the Microsoft Office package installed on your machine, just remove only this feature and leave the rest of the programs as it was. Check your computer for any possible errors.
Use a disk utility application to check the system. Install Microsoft Office Outlook 2007 then check if this fixes the problem. Be sure to supply the application with the correct username, password, smtp address, and or port number.
