Good Day Friends!
Anyone familiar with the Eximioussoft GIF Creator ? I’m about to install the Eximioussoft GIF Creator on my Windows XP desktop computer. I’m in the middle of the installation when suddenly the installer stopped working and disappeared. When I try to run the installer again, it’s not showing. Can anyone please help me? If you have tried this, then please help. If you can give the steps in the installation, it will be very helpful.Â
Thank you very much.
Problem with Eximioussoft GIF Creator?
Hello Ameliabelindaa,
As you have mentioned that you are facing problem during the installation of an Eximioussoft GIF Creator. There could be two reasons for this. If you install the application from a CD and the CD is not original or if you downloaded it from the internet and the file get corrupted somehow then it might possible to stop the installation in the middle. So I would suggest you to download the file from reliable site and before installation just disconnect your PC internet then install it. Hope this will help.
Thank you.
If you are installing EximiousSoft GIF Creator but the installation ended unusually, check again the program’s system requirements and verify that your computer meets those requirements. The latest version of EximiousSoft GIF Creator supports 64-bit Windows XP, Windows Vista, Windows 7, Windows 8.x, and Windows 10. It requires 1 GHz or faster Intel or equivalent AMD processor.
If you downloaded the trial, I’m not sure if there is a trial period but check the program during the installation for details about the expiration period. If the problem continues, just download the latest trial again: EximiousSoft GIF Creator. You can download the installer in ZIP and EXE formats.
The program is recommended for use on 64-bit Microsoft Windows but you can also install it on 32-bit Microsoft Windows.
