Hi there,
I have recently upgraded to Photoshop cs6 and have been an absolute joy to work with. The problem is that the fft plugin seems to have broken for some reason.
My Adobe cs6 application always seem to freeze when trying to apply the fft filter.
Can anyone guide me on how to remedy the fft cs6 broken plugin without reinstalling the whole software.
Thank you.
Problem with fft cs6 Plugin
Greetings Lewis Rodriguez,
I haven't had much experience with FFT filter. But since the FFT filter is a 3rd party filter high chance is that CS6 doesn't support FFT filter in its current state. It would probably take someone who is the author of the FFT filter to try to fix it and make it work in Photoshop CS6.
This is the usual problem with the third party plugins or add-ons when the new versions of software come. I'm sorry but I don't think there is a solution for your problem right now. You'll probably have to wait a little and then Google FFT plugin or Fast Fourier Transform plugin for Photoshop CS6 and then remove the one you have and then install the new downloaded one.
I hope this helps you.
