Problem with file creation in ms office word 2007
I have add the ins option in my ms office word 2007 which provide with the option "save as PDF".
But it is not working or doing anything. I hit the command, but it is no use.
I need to know how to make this work so that I won't need to use any other software to do so.
Kindly someone help me with this issue.
Daniel Murdoch
Answered By 0 points N/A #108447
Hi and good day Daniel Murdoch. I've got the solution for you to save your document into PDF.
Instructions:
1) Instead of clicking 'Add-ins', click the Microsoft Office button (it is the circle logo on the left of 'Home').
2) From the drop down menu that appears, click 'Save As'.
3) Then in the window that appears, Choose 'PDF(*.pdf)' as a file extension under the 'Save as type'.
4) Click save and your done.
The Microsoft Office Word 2007 "save as PDF" add-in is free and great to use without needing any other software. I hope that this answer will help you completely. I've posted an image to show you how it is done.
Thank you very much.
