A problem has occurred with the licensing of this product
I just downloaded Adobe CS5.5 Master Collections and I tried by opening one of its applications, it came up with the following message: "A problem has occurred with the licensing of this product. Restart your computer and re-launch the product… Error: 213:10"
I restarted the application and tried it again, with the same program and few others. None of them worked and they all came up with the same message.
Help? Do you have any idea that will let me open and use this program?
Configuration error
A problem has occurred with the licensing this product. Restart your computer and re-launch the product
Error: 213:10
https://helpx.adobe.com/support.html
OK
