Problem with high tone of nokia
Hello everyone,
I am using nokia phone. On my phone,  wake up tone is very low. I increase the volume to maximum, but the result is same. Can anyone tell me what is the problem with high loud tone nokia, please help me.
Best Answer by Johnny Mrmarshall
Answered By 0 points N/A #149965
Hello, Wyatt! You have not clarified about your NOKIA’s situation. Is it for every tone or wake up tone only? After all, you have to check it firstly. At the same time, I think it's the earphone connection problem which may be happening for all tones. If you have got it's OK, you can go to the mobile hardware mechanics. You can try this!
Answered By 0 points N/A #149966
Nokia is one of the most popular mobile phone companies, so most of their phones are very popular overall, and all of their phones have the best service.
I would like to know which Nokia model you use. All phones have different ringing volume and alarm volume options, so you must check and re-check this function to see if you have the ringing volume set to the maximum. If you find many volume differences between your ringing and alarm volumes, then it is best to take your phone to a mobile service center.
Answered By 10 points N/A #149964
Hi Wyatt Richardd,
Only wake up tone or all tone? If all tone then it is sure that there are sound problem with your Nokia mobile phone or only wake up tone then I think Nokia company believes that sleeping person means half dead person. That's why they are using low loud tone.
Best of luck
