Problem How To Install Visual Basic 6.0 Solved
I am having problem in visual basic 6.0 on my PC and it is causing me a lot of trouble. I need help on how to install visual basic, so guys please help me with this. Thank you.
To install visual basic 6.0-
That’s it.
Before installing Visual Basic 6 on your computer, make sure your machine meets the requirements. Visual Basic 6 supports Windows 95, Windows 98, and Windows NT 4. It requires 90 MHz or faster Intel Pentium processor, 640 x 480 minimum screen resolution, 24 MB RAM for Windows 95 and Windows 98 and 32 MB for Windows NT, and 48 MB free space.
Since this is a commercial software, you need to have a product ID to install it otherwise you can stick to a trial version if there is one available. If you purchase the software in a CD, the product ID is on the surface of the disc. If you don’t have a product ID, you need to purchase one to install the application.
Notifications
