anville
10 points
Posted on - 10/31/2011
Hi experts
I want to know Is there known problem with HP or Ridata? Because while I’m trying to copy from my HP Pavillion a1123 computer to a regular blank CD have a trade name of “RIdata” but it’s not working. so can anyone help with that
Thank you
harolds
Problem with Hp or Ridata .
Hello Anville,
In isolating this problem all you need to do first is re-install your burning software or install burning software. Some Blank CD is not compatible with your CD/DVD drive like buying fake blank CD/DVD. You need to refer also to your CD/DVD drive guide about compatible medium type and speed. If you have a genuine blank CD try to check if it works so may identify the difference between the regular CD and genuine CD.Try to clean your CD/DVD drive with CD cleaner that has a small brush which sweeps the dust in the optical lens and don’t touch the lens with your finger.
