Problem that I encounter while using SAS.
Could anyone please help me with this problem that I encounter while using SAS. I was trying to set a subset depot, when all of a sudden the following error message has occurred:
I have no idea how resolve this kind of error. Please help me. Thanks in advance.
Error: WBT – SASDepotSubset.exe
Error: C:SAS Depot SubsettingUtilitySASDepotSubset.exe
3074: Expression continues past expected end.
On line 440 of \tappant…evbinSASDepotSubset.wbt
msg = "ERROR: The specified input SAS Software Depot appears to already be a subset
SAS Software Depot. SASDepotSubset", myversion, "cannot proceed".
Winbatch 32 2010A
WIL Version: 6.10aja
Answered By 590495 points N/A #145069
I think you don’t need to set a subset depot anymore because as what was stated in the dialog box you posted, the SAS Software Depot you indicated as input appears to be already a subset SAS Software Depot.
You can not set it as subset software if it is already a subset application. You will just keep on receiving that message if you’ll try doing it again.
For other problems that your machine might have, you may check your computer for any possible errors. Use a disk utility application to check the system.
For a much thorough diagnostics on the system, use a disk utility application like Norton Utilities or Norton SystemWorks.
