I have a problem when connecting to a computer that is running Internet Information Server (IIS) 4.0 or Internet Information Services (IIS) 5.0, I get error message: HTTP Error 500-13 – Server too busy.
Is there a solution for this problem?
Thank you.
john.s
Problem with IIS 4.0 or IIS 5.0
The cause can be due to the server is not in the position to satisfy the request due to the internet traffic or it may be using 100% of your processor resources.
Visit windows IIS server website and download latest critical updates
Because there can be several reasons why you are facing this problem, it is a better idea to visit the below mentioned website and get the solution according to your needs.
This error is common since it is faced by lots of people. This error shows that the server is unable to manage the concurrent HTTP traffic since it is too much.
Some parameters that allow you to increase the connection numbers may exist .This is if the load to the server isn’t too much.
You will also be required to check if the ASP requests are executed in a sufficient time.
To do this, checks the queue to the ASP requests and the time they were executed.
Microsoft recommends an upgrade to IIS version 7 or a recent windows server.
